Attempting to use double subscripts to plot for unique circular segments. Can do it one at a time.
john_clark
I am using Mathcad Release 15.0 and DatecodeM050
Need to plot circular segment for four different cases. Need help setting up. see page 19
Sheet one dose it individually, Sheet two wit T on name is my attempt to do this. See page 19.
See sheet
Don't know how to upload my sheets.
Hi John,
Here is one way:
Cheers
Terry
9 REPLIES 9
Hi
Look below the text box used to post and you will see a location to drag and drop files or browse the computer to upload them.
Cheers
Terry
LucMeekes
(To:john_clark)
1. I'm afraid your problem is not solved.
2. This part of the forum is for installation and licensing problems. Your problem would get more attention in another part of the forum: https://community.ptc.com/t5/Mathcad/bd-p/PTCMathcad
3. Your sheet is quite overwhelming(ly large) and it's not clear (to me) what your problem actually is. If possible, condense your file to just the plotting problem, with a simple example of what you want to achieve.
john_clark
(To:LucMeekes)
Thanks for the response.
You site is a nightmare to navigate.
See page 19 for the issue. This was in the notes.
Thanks again.
jmc
LucMeekes
(To:john_clark)
It's not 'my site', it's PTC's site, for users of their software (such as myself) to interact. But you're right, the PTC sites are a nightmare to navigate. That's been so for a long time, for reasons unknown (it least unpublished).
Your problem is still unclear to me.
The problem is somewhat clear.  On page 19 is a plot of a segment/chord of a circle.  The plot is changed from one of four possible diagrams by changing a variable kk above the plot.  The poster wants to automate all four.  Not sure what automate means - all four at once?
Cheers
Terry
I’d like to combine 4 plots onto one.
Thanks for responding
jmc
Hi John,
Here is one way:
Cheers
Terry
Thank you again.
Works perfectly
jmc
