Chart component functionality
AS_9781967
7-Bedrock
There is no placeholder for units in chart component The old plot had unit place holder for scaling the graph units This seems to be missing in MP 7
Also using the chart component in the input area they are not automatically Assigned units to x and y expression I cannot see Corresponding base units displayed which makes it even more difficult
What is the solution for this??
LucMeekes
(To:AS_9781967)
Use the built in (old) plotting facility. The new chart component is a badly integrated third-party add-on.
Or was there a specific reason for you to use that new component...?
Yes I can use the old plot however wanted to go through the chart component to check the functionality so it seems like a huge missing in the new graphing functionality
LucMeekes
(To:AS_9781967)
Well, new...? It's in since Prime 5 and provides gridlines. But it has had complaints ever since.
See here, here, and here to name a few.
JeffH1
(To:AS_9781967)
The 2D Chart Component does not support units.
The solution is to divide each of your expressions assigned to the X/Y pairs by the units that you want the values to be displayed.  For example,
This is identical to how this was done in Legacy Mathcad.
