Complex Numbers in Polar format
bhoffman
I just installed MathCad and I’m wondering if there is an easy way to display complex numbers in polar format, or even preferable display it in degrees.
For example, say I have a resistor and inductor. R1= 10 and L1 = 10j. I would like to display it as:
R1 + L1 = 14.14 with a 45-degree phase angle.
I see some stuff that might be help from about eight to ten years ago, but I was hoping there is much more simple way with Mathcad 3.1
RichardJ
(To:bhoffman)
Put the cursor in the units placeholder in the result, select the format you want from the menu:
RichardJ
(To:bhoffman)
Thank you, it works great.
In old Mathcad
