I opened the worksheet (that was created in Mathcad 11) in Mathcad 15 M030 version. The document is rather large and I can not edit the contents of the file and select anything in therein. What is wrong with this file?
No,
If you go to "tools" & then "unprotect worksheet" it needs a password.
Without the password your options are quite limited.
There are, however, highlighted regions that allow user interaction
regards
Andy
No,
regards
Andy
Hi Andy,
Thank you. Yes, I forgot about this option.
