Define a Vector for solving equation
bhg1993
I would like to solve this symbolic equation and save it in a variable. Why is this not possible?
Assuming you want to use the solve block, would the following help?
LucMeekes
(To:bhg1993)
Your b=1 needs no solution, it is what it is, it can be used to solve s as a function of c, or the other way around.
This is how it should work:
LucMeekes
(To:bhg1993)
Or were you looking for this...
bhg1993
(To:Werner_E)
Thanks for your solutions. Yes, it was a fast example and b=1 makes no sense.
