HELP CONVERT FILES
aalves-3
HELP CONVERT FILES
Hi
This is my first time making use of Mathcad. Would anyone be willing to convert these two legacy files please?
(I am using the Prime 3.0 trail.)
Werner Exinger
I noticed that you are very active and helpful on the community. Could you help please?
14 REPLIES 14
Angela you have post your question in the wrong forum.
I think Ryan Kelley‌ can move it for you in the Mathcad section.
Marco
Thanks for notifying me, Marco Tosin‌. I've moved this discussion into our PTC Mathcad‌ product community.
StuartBruff
(To:aalves-3)
Angela Alves wrote:
Hi
Hi Angela,
Could I suggest that you upgrade to the Prime 3.1 trial?  I've converted the files to 3.1 format and attached them.  Unfortunately, Prime 3.0 can't read them, so if you can't upgrade to 3.1, then somebody with Prime 3.0 will have to help you.  But somebody should be along soon! 🙂
Stuart;
Converted to Prime 2 - should be readable in 3.
Andy
You can also find a thirty day free trial of Mathcad version 15, which can read (and execute) those files directly.
Angela should be able to download M15 M040 from here: http://www.ptc.com/product/mathcad/free-trial
However, it will only convert to Prime 3.1 ... 😞
Stuart
RichardJ
(To:StuartBruff)
It will convert to whatever version of prime you have installed.
StuartBruff
(To:RichardJ)
I am delighted to be corrected.
Stuart
That's right. The conversion depends on the installed version of Mathcad Prime.
StuartBruff
(To:VladimirN)
Out of idle interest, given that there are differences between the "Prime 1" version of Mathcad 15 (M???) and the "Prime 3.1" version (M040), do any of these affect the corresponding Prime Converters (eg, things that no longer convert or convert differently)?
Stuart
RichardJ
(To:StuartBruff)
Are you sure that's the M040 installer, and not the M030 installer?
StuartBruff
(To:RichardJ)
It was when I downloaded it, he says hesitantly, fearful of further embarrassing himself through ignorance ... although you would have thought the decades would have cured him of this by now!   that's cured of the embarrassment not the ignorance, that's beyond cure.
Stuart
RichardJ
(To:StuartBruff)
OK. Thanks. Last time I checked the trial version was still M030, but if I know it's M040 I'll go to the effort of downloading it.
Yes, I'm lazy
Absolutely wonderful. Thanks for all the help and suggestion.
