Hallo,
I would like to ask for your experience. I need to find the volume with triple integrals between 2 cylinders. They are not along the same axis.
To imagine how they are found, they form a cross, like this: +
The first one is an ordinary cylinder and it follows the form z= 3 sin (phi). This was really easy.
The second one is an elliptic cylinder. Here are starting the problems. The area of this second cylinder is given by x^2/a^2+y^2/b^2. For a = 2.6 and b= 3.0
But I just can transform this second one into cylindric coordinates and at the same time turn it 90° from the first cylinder to form this "+" cross.
Do you have any idea?
Thanks a lot!
Best regards.
The trick to the integration is to set the limits correctly.
I wouldn't bet lunch that this was right.
Here is a basic MAthCAD document... it is missing the main part =S
Is this what you mean about two cylinders?
If so, then we can move forward to develop the integral
Hi Fred
You´ve got it! Wow, yes it is like that. How would you start the integral?
Due to a some reason, I can not see the graphs...
Thanks y lot!
Right click on the graph and uncheck "border". Depending on your OS, that might fix it.
Hi Richard,
it fixed it!
Thanks!
It is getting more and more exiting. Now, how can be the volume found? It looks like you have the answer is almost there.
Hi Fred,
I have solved the problem in another way. But I am very interested in the way you are solving the problem. I would like to ask you if you could continue with it? It was really sophisticated and I would really like to see your answer.
Here is my version as well.
Thanks!
I wouldn't bet my lunch on anything
Mike
Thanks Fred,
I wouldn't bet my lunch as well... Sorry for not answering before. My Hard disk just died.
I think it is quite well, numerical approaches give a little smaller value, but it is ok. I need to learn more about MathCAD to fully understand that what you did.
Regards and thank all of you for helping.
Hello!
Hope this helps: https://www.math.drexel.edu/~jwd25/Calc4_Winter_09/lectures/Lecture8B.pdf
Thanks Vladimir,
it was quite helpful, however, the definition of the function is still not perfect...
