I have a variable definition that is dependent on previously-defined variables, and I am using the inline evaluation to show the result. When I change the previous variable name above, 1) the old name shows up as red (which I expect) and 2) the old result still shows up in the inline evaluation! I expect for there to be NO result shown. This is potentially dangerous since incorrect results are being displayed (an ongoing issue with the inline display feature).
As I have gone through correcting my equations, sometimes I find that when previous definitions are corrected, later assignments are NOT updated. See attached for one such example. y- was just corrected and displays correctly. In the region below the variable y- remains red and the expression does not calculate. In this particular case I still have old variable names in the lower expression, but only the "OK" variable shows up as red while the "NG" variables do not.
As much as I like the inline evaluation feature in principle, it's still quite buggy.
v14 M030
Preston
