Mathcad-Ansys
ptc-2620282
Mathcad-Ansys
Hi, I use Mathcad and Ansys. To make Design of Experiment, I would like to use Mathcad and Ansys in common. I found the plugin on the website but I have problems with the install. I modified the reg file. The Mathcad icon appears when I launch Ansys but when I click on Mathcad, an error appears (see the file attached). I need help please. Thanks Yann
Yann, Did you ever get this sorted? I am having install problems as well. Mike
ELSID
(To:ptc-2107009)
There was a similar issue with another user in the main collab. This forum is kind of like a back water. go to http://collab.mathsoft.com/~mathcad2000. Do a search for Autocad. It may have been the Revit extension.
