Mathcad15 File Will Not Open
coberg
6-Contributor
Good Afternoon,
I created a design template for a steel diaphragm.  I completed the template yesterday and saved the file and restarted my computer. Upon trying to open the file this morning, the file will not open.  I do not get any error message when trying to open the file, rather the MathCAD splash screen pops up an then the program shuts down.  I cannot locate any backups or other versions of the file stored locally.  Is anyone able to help recover this file for me?  I am not sure how best to do this.  The file is attached.  Thank you in advance for any help with this!
LucMeekes
(To:coberg)
I may have fixed the file, please see attachment.
I've replaced one region with a text. You can search for:
 Offending region
to find where that happened. That is, if the file opens for you...
6 REPLIES 6
24-Ruby V
(To:coberg)
Unfortunately I can only confirm that Mathcad crashes when trying to load the file. I don't know what the reason could be.
Looking in the file I noticed references to files on drive P: and also files on a onenote share. Are these accessible when you try to open the file?
LucMeekes
(To:coberg)
That's an impressive amount of work to loose.
You can still view most of it with my tool, in case you need to recreate it...
LucMeekes
(To:coberg)
 Offending region
Great work! I could open it in MC15 and so I guess the OP will be able to do so, too.
coberg
6-Contributor
(To:Werner_E)
Werner,
Yes I was able to open it!  Saved me a lot of time and rework.
Carl
coberg
6-Contributor
(To:LucMeekes)
Thank you! That did it! I appreciate the help! You saved me from having to rework the entire sheet!  I did luckily print it before it decided to not want to open, but I would have had to redo it all by hand. Thank you again for your help!
