More Units
MikeMcDermott
More Units
We use the following which are missing
nH, mF, mOhm, GOhm
Also units should be in order. I currently see
F nF pF uF
Shouldn't it be
F uF nF pF
I thought the order was base unit and then the multiplier times the unit, but that's not the case with potential. There needs to be some consistency here.
I would iike to have units implemented so that I can pick a base unit and any SI multiplier.
MikeArmstrong
(To:RichardJ)
I fully agree. I also would like tables to be able to display the unit of my choice, not only SI units.
Mike
I assume by "display" you mean "automatically display". Can you not choose a unit system in Prime? I have never looked, because I always use SI..
MikeArmstrong
(To:RichardJ)
I haven't got Prime at the moment but if I remember correctly you cannot display a mixed unit matrix (results) in anything but the base units the worksheet is currently set, I could be mistaken though.
Mike
I think the best "more units" in Prime 3.0 will bee so - http://communities.ptc.com/docs/DOC-2152
See the picture too:
http://communities.ptc.com/servlet/JiveServlet/downloadImage/102-2152-1-25787/450-232/If-Units.png
