Negative inverse transposed matrix
PhilipLeitch
I have a text book example I can't translate into Mathcad.
They provide a 2x2 matrix as follows:
1 0.051
0.051 1
They then say to transform it by "transpose of the inverse of the square root" of the above matrix.
They use notation that is M followed by a superscript of -1/2
(M^-(1/2))`
The result should be:
1 -0.03
-0.03 1
I don't know how to square root a matrix, and square root of individual values doesn't provide the "correct" answer.
Any ideas?
Thank you.
Philip
___________________
Nobody can hear you scream in Euclidean space.
6 REPLIES 6
Use eigenvalues for generalize functions definitions from complex to matrix domain.
Regards. Alvaro.
Thanks. That worked perfectly.
I wouldn't have been able to work that one out.
I'm using it to find the canonical coefficients of a canonical correlation. I can then use these correlation coefficients as part of a descriminant function analysis.
The book I have skims over the calculations because it assumes you just plug the figures into SPSS and get the answer.
Philip
___________________
You could also use a Given ... Find solve block if you want to avoid using eigenvalues/vectors - see attached.
stv
On 1/5/2010 9:20:26 AM, stv wrote:
== You could also use a Given ... Find solve block if you want to avoid using eigenvalues/vectors
Or the Denman-Beavers algorithm ...
Stuart
Thanks for the various options.
Philip
___________________
Maths-matix aren't always "true" and clear cut.
Book notation make them worst.
Your example seems to come out indirectly from:
jmG
