Is there a way to remove the MathCad Express watermark from a printed MathCad document?
Not a legal one that would be compatible with the licence conditions you have accepted.
Or a better answer may be "Sure there is a simple way to do - buy the software and the watermark is gone" 😉
If you payed for a Prime license and the programme still runs in the free Express mode with limited functionality, then something went wrong.
You should contact PTC support to clarify why your licence file is not recognised as valid by Prime.
If you have a paid subscription and the watermark is still there then you need to reconnect to your license file. Under options in the M pull-down menu (where you find "save as") is the options tab.
