Hi all,
I want to know,
What is the maximum number of pages in mathcad ?
Thank you
vetri veeran wrote:
I want to know, What is the maximum number of pages in mathcad ?
It's probably resource limited (eg, you run out of memory, you can't add more pages).
However, I thought "Good grief! What are they going to write? "War and Peace"? Which was a mistake, because I then had to google the text of Tolstoy's epic novel and paste it into Prime ...
It took some time for Prime to go through the process of pasting, but it ended up with 1141 pages. This is about 5 times the number of pages of the longest worksheet I've written and most are less than 50 pages.
Stuart
I've never (heard of anyone) run into a limitation on the number of pages.
Why your question?
Stuart
There's no upper limit, but Prime gets very slow for large (10s of pages) worksheets. That will be fixed in the next release.
Oh, I don't know. It just depend upon how you define "slow". For example, I opened a 110 page Prime 3.1 document and it only took 1 hour to scroll a couple of lines. Now, in geological terms that's pretty damn fast! Then I tried adding a few lines ...
Stuart
And what are the computation stretched so pages already more than a hundred?
P.S. Maybe it was a decimal place of pi?
What's your confidence level on this?
Also, has PTC clarified when we should expect to see 4.0?
Fair to middling, based on what I've heard. There should be a big improvement in switching between Page and Draft mode (I usually work in Draft mode, so that will be much appreciated). General speeds of movement around a large worksheet and editing should also be noticeably improved.
Based on the information in one of Vladimir's posts (Re: VERY IMPORTANT: Critical issues with Mathcad 15.0 M040 in handling matrices with 256 or more elements.), Q4 2016. Which is probably project management speak for Q1 2017, with a bug fix in Q2/3.
Stuart
Very high. I've seen some of the benchmarks.
Prime 4.0 release date as 4Q, 2016. This is a delay of 6 months or more. I would be surprised if they made that date.
One would expect a successor as Prime 1.0 being an advancement and improvement over its predecessor Mathcad 15 and not missing a single feature of the older version.
Given the facts about Prime, you can't say that Prime is delayed for a few months, its delayed for many decades (infinite, given that its not intended that it will ever fully live up to MC15).
WE
Thank you all
