the PDF file from http://www.ptc.com/appserver/wcms/resourcecenter/mathcad.jsp?&im_dbkey=132635&icg_dbkey=888&lang=en
I am interested to see it, but the website says "PTC.com Account Not Authorized"
Vladimir is correct. All users, whether they have maintenance or not, should be able to download the PDFs and Mathcad files posted on Mathcad Engineering Resources, http://www.ptc.com/appserver/search/mathcad.jsp.
In fact, the PDFs are specifically there for people who don't have Mathcad or that particular version.
I'll investigate why that PDF can't be downloaded.
Mona
Becuase (like me) you are a lesser mortal that has not purchased the favors of the PTC gods via the maintenance program.
If you right-click, you can choose Save-As, and this allows you to download something. However, neither Acrobat, Mathcad 15 nor Mathcad Prime 2 can make sense of the result (whatever you change the extension to)!
For some reason, you can download the Prime 1 version (just above the "pdf" version) with no problem at all, and it works just fine in Prime 2!!
Alan
It seems that this is a bug.
Mona
That PDF was expired. The web team reset the expiration date and it should be fine now.
Mona
PDF works fine but Prime worksheet automatically saved as a "zip" archive file.
That is why I posted the question. Thanks for fixing
