matching two expression
zaki_rhm
6-Contributor
Hi, how to matching this two equation for define a and b
c(t):=2.47+0.0036t
c(t):=a+bt
LucMeekes
(To:zaki_rhm)
You have 2 unknowns, so you need 2 equations.
The best two equations in your case are:
a=2.47
b*t=0.0036*t
And have mathcad solve these simultaneously:
Hi. If c(t) is given, and you want to get a and b, can use the coeffs symbolic keyword, or evaluate c and c' at t=0.
Best regards.
Alvaro
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
