Advance Tags are missing in Thingworx Kepware Edge
pshashipreetham
Gone through all the TKE Docs, but not able to find the Advances Tags creation in the TKE
Do TKE has Advance Tags ?
@paic @c_lowy @slangley @CarlesColl @VladimirN @AnnaAn
Shashi.
Shashi Preetham
1 ACCEPTED SOLUTION
Hi Shashi,
Understood.
But in current TKE there is no alternative for the advanced tag, and I believe the ThingWorx subscription to the datachange is the only way to achieve similar function.
Thanks!
5 REPLIES 5
The ThingWorx Kepware Edge(TKE) does not have advanced tag plug-in.
For what TKE provides please take reference to this page:
https://www.kepware.com/en-us/products/thingworx-kepware-edge/
Thanks!
Br,
Anna
Hi @AnnaAn ,
This Means can't use the advance Tags in TKE, therefore do you have any alternate solution with similar feature to the advance Tags ?
Shashi
Shashi Preetham
Hi Shashi,
Thanks for the reply.
As said there is no alternate solution in TKE, and if you deployed kepware in Windows you could consider to install KEPServerEX or ThingWorx Kepware Server(both are same Kepware products just from different sales channel). If this is impossible and if you are feeding the TKS data to ThingWorx platform, you could read the raw data from kepware to ThingWorx and then subscribe to the datachange and then add some logical calculation to the bound properties which could do similar job to advanced tags.
Hi @AnnaAn ,
As of now the Calculations are done based on the Event.AnyDataChange in the subscriptions which is giving some performances issues. That's the reason Advanced Tags were used, But as moving to TKE, Advance Tags are needed.
Shashi.
Shashi Preetham
Hi Shashi,
Understood.
Thanks!
