Hi Developers,
I'm starting on a project which involves Thingworx manufacturing apps. I need to know if the following versions are compatible with each other.
I couldn't find any compatibility matrix between the above mentioned products.
In the PTC Smart Connected Applications page should i download the Manufacturing Apps Extension from
1. Release APPs >> ThingWorx Manufacturing Apps Extension >> Most Recent Datecode (or)
2. Release 8.3 >> ThingWorx Manufacturing Apps Extension >> Most Recent Datecode
Is the Industrial Connectivity version dependent on ThingWorx Manufacturing Apps Extension and ThingWorx Platform?
Please share any useful links.
Thanks & Regards,
Saran
As a general rule, you need to install the same major/minor release for both the platform and the extension. For example: for ThingWorx 8.3.x, you need to install the Mfg Apps 8.3.x extension.
Some changes have occurred with some of the newer releases and you can now find the Apps 8.3 extensions under ThingWorx Platform on the Support site.
The ThingWorx 8.3 system requirements can be found here.
--Sharon
If my response has answered your question, please mark as Accepted Solution, for the benefit of others who may have the same question.
--Sharon
