On a side note, when entering my question I got the error message as below. I could not identify any "highlighted" error and had to guess that I have to select a location first. An actual highlighting of that button or any kind of hint in that direction would be very helpful.
Thank you
Benny
Hi @bbeuckSIG
Thanks for pointing that out. The absence of a meaningful error message in this situation was recently pointed out by another community member and we should have a fix for that in an upcoming update.
