Creo Parametric CAD Modeling Challenge
For this seventh Creo Parametric CAD modeling challenge, you will be creating a fully mechanized assembly of the FTC game piece manipulator from FTC Team 5828 - E.M.P. Chaos. You need to know basic Creo Parametric assembly constraints, Kinematic constraints and assembly structure to complete the design. It is a complex model to create, and you will need to master Creo Parametric Pin constraints and limits to make it work correctly.
HINTS
Assembly Structure Hint
GAME_PIECE_TUBE.ASM
