Creo 7 stops responding
Kappy
I recently installed the creo student version and when I started using it after just drawing 1/2 curves and making a basic solid the programs goes into not responding mode. it resumes after a min or two and then again goes in to not responding once I click just 1 feature to edit.
My system deets are -
Processor Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz 2.81 GHz
Installed RAM 16.0 GB (15.9 GB usable)
System type 64-bit operating system, x64-based processor
Windows specifications
Edition Windows 10 Home Single Language
Version 20H2
Installed on ‎11-‎04-‎2021
OS build 19042.928
Experience Windows Feature Experience Pack 120.2212.551.0
MartinHanak
24-Ruby II
(To:Kappy)
Version 20H2
OS build 19042.928
start Task Manager and check whether some application is running hight during Creo "no reponse" period. Also  check disk activity.
Martin Hanák
Kappy
(To:MartinHanak)
The task manager has no other processes running when creo is running except for the brave browser and combining both of them the RAM usage barely hits 6 GB out of 16 GB. Plus I have disabled all the startup process that might hinder the ram usage. The CPU usage also hits around 5% when creo goes in not responding mode.
PS. If you are wondering that my C: drive is full then it's not I have 30 GB of free space.
MartinHanak
24-Ruby II
(To:Kappy)
Hi.
my last tip ...
Add following option into config.pro file, start Creo and test its functionality.
graphics  win32_gdi
Martin Hanák
Kappy
(To:MartinHanak)
Hey, thanks for the suggestion but the option you suggested still doesn't work for me.
