Before I was using Creo 4.0 Student darning my bachelor, then I have suspend my study due some Family Issue, I have recently get back and installed the new version 8.0.3.0 for practicing, There is Only a few Manufacture option Does not work, once I set up the Name for the Part and click "OK" the window crash before it open and Close itself , The Next time I try to Create new Manufacture Part the auto system Keep Name them as they were opened (mfg0002,mfg0003,... etc.) while they are actual didn't open it all.
also some time it show me my license are Expired, then it's Activity, Can anyone related to that?
Sadly Creo student versions doesn't include manufacturing extensions. That is why you are having issues.
The expired license message is due to an older license that is on your computer in C:\ProgramData\PTC\Licensing
Any older expired license will give that warning, so to solve this simply delete any license older then 1 year from the location C:\ProgramData\PTC\Licensing.
I hope this helps!
Alex
I hope this helps!
Alex
I do thank you for your Help, although my win doesn't have that directly, I only have C:\Program Files\PTC there's no License File in there while it is working the License isn't a problem I can move on.
Please note that the folder is ProgramData and not Program Files. The folder is hidden.
~Alex
