Creo Agent is missing
LV_10213867
2-Guest
Once I installed the creo program, but apparently I made a mistake with the installation because it shows me the issue that the creo agent is not correctly installed. Please give me a solution for this issue.
Read this tip - "Creo Agent did not initialize correctly. Please contact technical support if the issue persists": https://community.ptc.com/t5/PTC-Education-Forum/Creo-Agent-did-not-initialize-correctly-Please-contact-technical/m-p/732275#M12112
I already had it installed but I deleted and now the program can´t find it anymore. Maybe it´s still on the pc, but I can not find it either.
installation package is available inside Creo installation media. For example CR8_030_64bit\install\addon\creosvcs_64.exe
Martin Hanák
