Creo_For_Schools.bat file Access Denied in Creo 10!
JG_10930131
2-Guest
Help! I'm confused by what this error is telling me. Am I supposed to remove all the permissions for SYSTEM in the folder? Should it be set for Full Control of everything? Just want to get this setup so I can do some learning. using "How to Model Almost Anything"
If you see "Access denied" messages above, you must change permissions so that
The system cannot find the file specified.
changing the folder permissions, browse to your "creo_standards" folder and
run the configure.bat file to select a drawing standard and unit system.
if you open Creo_For_Schools.bat in Notepad then you will what files are copied and where. You can do same steps manually using File Explorer.
The problems is related to default installation directory. You can change access rights to directory tree started at C:\Program Files\PTC directory.
Martin Hanák
OK, so what exactly am I looking at here? I don't work in .bat files at all. I see what files I'm copying, but not sure where I'm copying them to.
rem ------------------------- choose 1 - ASME drawings with INLBS unit system -
rem
:ONE
rem
xcopy /q /y "config_files_schools\config_inlbs.pro" "..\text\config.pro*"
xcopy /q /y "config_files_schools\creo_parametric_admin_customization.ui" "..\text\creo_parametric_admin_customization.ui"
xcopy /q /y "config_files\appearance_edu.dmt" "..\graphic-library\appearances\appearance.dmt*"
xcopy /q /y "draw_standards\asme_in.dtl" "draw_standards\standard_in.dtl*"
del "templates\*.drw"
xcopy /q /y "templates_asme_in\*.drw" "templates\*"
GOTO :MESSAGE
let's say that Creo_For_Schools.bat is located in C:\Program Files\PTC\Creo 10.0.0.0\Common Files\creo_standards  directory.
copy C:\Program Files\PTC\Creo 10.0.0.0\Common Files\creo_standards\config_files_schools\config_inlbs.pro file
to C:\Program Files\PTC\Creo 10.0.0.0\Common Files\text  directory and rename it to config.pro
copy C:\Program Files\PTC\Creo 10.0.0.0\Common Files\creo_standards\config_files_schools\creo_parametric_admin_customization.ui file
copy C:\Program Files\PTC\Creo 10.0.0.0\Common Files\creo_standards\config_files\appearance_edu.dmt file
to C:\Program Files\PTC\Creo 10.0.0.0\Common Files\graphic-library\appearances  directory and rename it to appearance.dmt
copy C:\Program Files\PTC\Creo 10.0.0.0\Common Files\creo_standards\draw_standards\asme_in.dtl file
to C:\Program Files\PTC\Creo 10.0.0.0\Common Files\creo_standards\draw_standards  directory and rename it to standard_in.dtl
remove files with .drw extension in C:\Program Files\PTC\Creo 10.0.0.0\Common Files\creo_standards\templates directory
copy files with .drw extension from  C:\Program Files\PTC\Creo 10.0.0.0\Common Files\creo_standards\templates_asme_in directory to  C:\Program Files\PTC\Creo 10.0.0.0\Common Files\creo_standards\templates directory
Martin Hanák
