I was following Getting Started with Creo Parametric Toolkit but something failed and I don´t know how to solve it.
I tried to open make_install.sln through Visual Studio 2022 and build the solution, but an error occurred.
It says "Cannot open include file: 'stdio.h'".
I searched info about that bug and tried many things like uninstall VS, install other libraries. However, nothing works.
I also built "Hello World" in VS to check if "stdio.h" is avalaible, and nothing failed.
I will really appreciate if someone could help me.
Thanks!
It´s working now. I have included every single header and library manually,but now it works
I had this issue, was able to resolve it by adding the stdio.h path to the project in the Include Directories... "C:\Program Files (x86)\Windows Kits\10\Include\10.0.22621.0\ucrt"
After is error was resolved I need to Library paths also...
C:\Program Files (x86)\Windows Kits\10\Lib\10.0.22621.0\um\arm64
C:\Program Files (x86)\Windows Kits\10\Lib\10.0.22621.0\ucrt\arm64
Will you please help me how you linked creo to visual studio. Please explain point by point it will help me in lot of things.
What was the fix? I'm not seeing it. I'm getting the same error and I'm not sure what everything was you added.
Sorry mate, It's been too long and I don't even remember the problem I had.
With my license, Creo Toolkit is not available so I removed it from my Creo Parametric Customisation and I can't even check it to help you more.
I wish I could help you better than I did.
No problem, thanks for replying. 🙂
