Hallo
ich habe soeben Creo 2.0 installiertund wollte eine Baugruppe erstellen leider konnte ich keine Baugruppe öffnen und keine neue anlegen
Es wurde auch kein Fehler angezeigt. Es passiert einfach nichts. Einzelne Teile funktionieren wunderbar nur eben das erstellen einer Baugruppe macht Probleme gibt es da einen Trick was man beachten muss?
würde mich über jede Hilfe freuen
Gruß
Tobias
Tobias,
I didn't know that you were wokring with Creo Direct. Unfortuantly at this time, the student license of Creo 2.0 Direct does not include Creo Direct Assemblies. That said, you should have no problem doing assemblies in Creo 2.0 Parametric.
Sorry for the inconvenience, please let me know if there's anything I can do to assist at all!
Hi Tobias,
Could you please attach a screenshot of the issue? I'm not sure that I've ever heard of individual parts working but not assemblies.
Hi
Thanks for your answer I just try to reinstall it
If the problem still persists I will make some screenshots
thanks
Tobias
Hi
Now I've tried after reinstall but no effects
Here are some screenshots
And here nothing happens
With a Single Part it is all fine
I hope it is no problem if my Nootebook This is my System:
Thanks a lot for every help
Tobias
Tobias,
GREAT
THANKS for your help
I didn't know that there are only some tools free for students
But now it works perfektly
So thank you very much without you I would never find the mistake In this case the problem was me and not the tool 😉 "Computers are only as smart as the human who uses it"
So thank you I hope now everything works perfekt
Thank
Tobias
