No FlexNet file installed with Creo Student version. How to insall it separately and connect it?
AB_10200489
3-Visitor
I just borrowed student version of Creo Parametric 8.0.3.0 from my friend. It was working fine in his PC.
I changed the MAC address to mine in the license file, but afterall that, on startup, it shows Error -8.
After hunting through the files, I found that there is no FLEXnet files, mentioned everywhere in the troubleshooting documents. So, How do I install this separately and connect it with my Creo. As I really don't want to download Creo again, because of data limitations.
3 REPLIES 3
"Guided Licensing & Installation Troubleshooter --> Error Codes --> Error (-8)": https://www.ptc.com/en/support/creo-admin-troubleshooter/error-code/other-errors/error-8
I am unable to download FlexNet from Reinistall License Manager section, it is showing I am not allowed to. I have tried other options as well.
please don't expect anyone to advise you on a trick.
Ask someone without "data limitations" to download installation package and use standard installation procedure mentioned in available documents.
https://apps.ptc.com/schools/references/install_creo8_schools_standard.pdf
https://apps.ptc.com/schools/references/install_creo8_unistudent_standard.pdf
Martin Hanák
