I'm defining Theta to be between 0 to 90 degrees, and when I reference it in the subsequent lines, I get an error indicating I did something wrong. Please see attached.
evaluate the range and then correct another errors.
Hi
sin^-1 function does not exist. Use arcsin() or asin(). I cannot remember the right name of trigonometric function.
Hi, sorry forgot to mention I fixed that too in the document i posted below, now the only error is theta_t.
I fixed two errors, I think it has to do with defining one variable with a range in terms of another but I don't know how to fix theta_t error.
Thank you so much, Martin.
