PTC Implementer - IBM I - Storage replication
AL_10953250
Good afternoon,
I have a customer that is using PTC Implementer on IBM I and we have a recurring issue after each DR Test.
The DR is based on storage replication in another Data Center and when we switch there is always a license issue for the new hardware. The workaround applied is using the RESET command and that adds it.
Unfortunately, i cannot find a manual on this application and I'm not familiar with it.
Is there a way to avoid this issue? Does the application have something HA build-in?
Any information is appreciated,
Thank you!
Try also requesting more information here - "Have a Representative Contact Me": https://www.ptc.com/en/products/developer-tools/contact-us
AL_10953250
(To:VladimirN)
Will do. Thank you!
You're welcome.
