I don't see the option to import a plan into ProjectLink, although the export option is there. Is there a way to bring something in from MS Project?
Walter
Yes, it should be listed in the Actions menu as shown. There is also a Microsoft Project plugin you can use to connect Microsoft Project with Windchill. It is located on the Software Downloads page.
Thanks, I think I was logged in as a member instead of PM and got a restricted list of actions as a result. My apologies for a rookie mistake.
