Standard Views Missing on Importing Creo 6 file
Shaun_F
3-Visitor
Hi All,
I've just dug out on old creo parametric file (attached in zip file) and opened in Parametric 9. When I look under View->Saved Orientations I don't get the standard lists of Front, Back, Top etc (see screenshot below). Do I need to somehow convert to latest Creo version to recover that, or is there something else I should do? Or do I need to start again?
Any tips appreciated.
Shaun
6 REPLIES 6
in the past someone simply used File > Import command without any other configuration to open import file in Creo. Because of this resulting file does not contain standard list of views. You have to create standard list of views manually.
Next time ... during import click Details button and set template which will be applied.
Martin Hanák
Hi Martin,
Thanks for your help - but I cannot see File > Import. I'm using the Educational Edition and all I see is File > Open as below.
The part file is over 10 years old so maybe its just too old to be properly read.
@Shaun_F wrote:
Hi Martin,
in the past guntrails.prt part was created by importing guntrails.stp file.
guntrails.stp file was opened using File > Import command and then saved as guntrails.prt.
I hope you understand this explanation.
Martin Hanák
Hi Martin,
Does that mean I need the stp file to regain full functionality?
Best
Shaun
Thanks Martin
