Unable to give dimensions.
Madhava
3-Visitor
I am able to select the edges to give a dimension, but it's not working. I am not sure if I missed something. Can someone please help me out here?
@Madhava wrote:
Hi, thanks for the reply.
Please watch the attached clip and let me know what you think....
use following steps:
  • click Dimension button
  • press and hold CTRL key
  • select geometry edge
  • select circle center
  • release CTRL key
  • click middle mouse button to place new dimesion
  • enter dimension value
  • press Enter key
Martin Hanák
9 REPLIES 9
VladimirN
24-Ruby II
(To:Madhava)
Please specify which version of the program you are using.
Hi, thanks for your reply, I am using student version (7.0)
please record a video showing your attempts and attach it to next reply.
Martin Hanák
No clip available.
Martin Hanák
please use computer application to record video, for example Screencast-O-Matic. Application enables you to get better video quality.
Martin Hanák
  • release CTRL key
  • press Enter key
Martin Hanák
Thank you very much, I am able to give a dimension now.
