Why the variable remains undefined?
RWickrama
6-Contributor
I defined a user-defined function: However the variable after the equal remain undefined.
Already I created similar functions. But, this one is giving me a hard time. Could someone help me please.
MathCAD Prime 4.0
3 REPLIES 3
Do not use = operatorat the end of a function creating!
If you define w and AB above your function it will evaluate using those value.  As Val demonstrated, using the function with other values will evaluate with those values.
Something like this?
