I found Kepware plans to release Linux Edge, which supports Ubuntu.
https://www.kepware.com/ja-jp/products/thingworx-kepware-edge/
If this is runnable in SigmaTile software, it means running on Raspberry Pi 3,
this helps me to use SigmaTile demo together with Azure VM without local PC for Kepware.
Could you share with me something if you have information regarding this idea, please?
Hi @anishi
I don't think so, cause Kepware edge is supported on Unbuntu, not sure the OS on the Rasberry should run this version.
Theoretically, you could run TKE in a docker container in Raspberry Pi. Documentation
