Hi!
For a few days ago i have upgraded my Creo Parametric 3.0 up to 4.0. When i try to open it, it says that quality agent could not run and all crashes. I have win 10 and M020 version of Creo if it has something to do with the issue.
Hey,
I just had the same issue as you after installing Creo 4.0 for the first time (0x06000012).
In my case I deinstalled the quality manager from within the downloaded folder:
(...\MED-100WIN-CD-410_M030_Win64\install\addon):
1. Right click on "qualityagent_64.msi"
2. Select deinstall
Afterwards I reinstalled the the quality agent, but I had to change the directory!
1. Again right click on "qualityagent_64.msi"
2. Change directory from "C:\Program Files (x86)\PTC\Quality Agent" to the 64bit folder where the rest of Creo is installed as well.
"C:\Program Files\PTC\Quality Agent"
3. Finish installation of quality manager.
4. Start Creo and it worked.
Maybe this helps someone.
Best regards
Hey,
2. Select deinstall
Best regards
worked for me, thank you very much!
Worked also with my 7.0 student version! Thanks!
How did you re install the quality agent?
please read https://community.ptc.com/t5/PTC-Academic-Program-Discussions/Licensing-Error-Creo-7-0-2-0/m-p/708655 discussion.
@Lemons you just saved my 90 mins of uninstalling, downloading, reinstalling. It worked! Thanks a lot🙏🙏🙏
I just tried these steps with my newly downloaded Creo 10 student, and technically the process was successful (ie. Creo stays open and appears to have full functionality) so thankyou!
However, I still get the 1st of the 2 errors (that I showed in this post linked below) which states "Creo Agent did not initialize correctly...". For now, I suppose it doesn't matter since my Creo is working, but this distinction feels worth noting.
"Creo Agent did not initialize correctly" error - ... - PTC Community
