Hole Chart
dbreen
Hole Chart
i am creating a custom hole chart for Creo Parametric 3.0 M030.
I've copied the default ISO.hol file into a location and specified this location in the config.pro with hole_parameter_file_path.
However when I open Creo and use the hole feature within a new part, the custom hole chart isn't displayed among the default list ( ISO, UNF, UNC).
As far as I know I'm doing everything as it is supposed to, so do you guys have suggestions?
DB
Kevin
(To:dbreen)
‌FIrst thing that comes to mind without knowing exactly what you did is did you rename it and give it a new title (I'd have to look up the exact parameter in the file header)? The file and header infor Marion needs to unique as far as I know.
Kevin
(To:dbreen)
dbreen
(To:Kevin)
I've only renamed the file. Haven't changed anything in the file because it didn't show up in the hole feature.
dbreen
(To:Kevin)
I've changed the THREAD_SERIES parameter in the file so that is corresponds with the file name, that solved the problem.
DB
