Computed Expression help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
We are using MKS Integrity 2009 SP5. Yes, I know we need to upgrade, but we are under-staffed.
I am trying to make a calculation (Computed expression Integer type field) work. When I try to edit an item I get an error "Division by zero has been detected processing the query on the server". I understand the error. I don't know how I can resolve it. What I am doing is dividing 2 integer fields to return a percentage. Example: field3 (Integer) computed expression: "field1" / "field2". These 2 fields are divided to give a percentage.
If field1 = 10 and field2 = 100 then field3 should display 10%.
However, if field1 and/or field2 has zero (default) then the division error is displayed. I understand you cannot divide a number by zero.
If field1 = 0 and field2 = 100 then field3 should display 0%.
How can I get it to simply calculate or say 0%, because that is what it should be?
Thank you,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi Daniel,
1. IMHO the field type of your computed "Field3" should be "floating point".
2. IMHO the computaion should be:
isEmpty( ("field1") / ("field2" + 0.001),0.)
HTH Matthias
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi Daniel,
HTH Matthias
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Is it safe to assume that I cannot mix apples and oranges. So all those fields should be floating point. Correct?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
As far as I know, the resulting field Type is the driver.
So, as long as you are calculyting a floating point field, the calculation may still contain integer values.
At least in the field definitions of the PTC ALM Solution this is used several times.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
All correct. The only one that _has_ to be float is the final computation. Others can be or not. Where integers are divided and nested, I've also had to multiply the ratio by 1.0 to prevent the result from being rounded to integer before the next operator is applied. THAT trick is the least obvious. When in doubt, try it.
