How do I change the deletion allowed field?
ptc-6854045
I attempted to delete a requirement but then received a message stating that I needed to change the "deletion allowed" field.
1 REPLY 1
In the Admin Client edit the type "Requirement" and enable the check box "May be deleted, controlled by the rule" (see attachment),
The rule can simply remain empty.
