Integrity 2009 SOAP
jdcc
Integrity 2009 SOAP
Hi guys,
I would like to ask if Integrity 2009 supports SOAP-based web services. I have service pack 6 installed. Do you have any documentation we can refer to?
5 REPLIES 5
jgorsline
(To:jdcc)
JDCC,
Yes, we do support SOAP. You can find more information in our Web Services Reference document:
http://www.ptc.com/WCMS/files/143568/en/WebServicesReference_2009SP7.pdf
jdcc
(To:jgorsline)
Hi Jeremy,
I don't have access to the location. I worked for a company and was given an MKS license but I do not know our customer details which are required to upgrade my access.
Could you please send me a softcopy via email?
Jeric
jgorsline
(To:jdcc)
jdcc,
Please contact our support department at 1-800-477-6435 to get your account straightened out for you.
Do you happen to have a usage sample for python? I've tried several methods and cannot get past the follwing exception:
SOAPpy.Types.faultType: <Fault env:Client: Endpoint {http://webservice.mks.com/2009/Generic}Generic_2009Port does not contain operation meta data for: {http://webservice.mks.com/2009/Generic/}command>
(the exception is similar regardless of what WSDL and command I try to use)
David
Hello David,
Unfortunately, I do not have a usage sample for Python.
If you figure it out, or if someone else has an example, please post it here!
Kael
Kind Regards,
Kael Lizak
Senior Technical Support Engineer
PTC Integrity Lifecycle Manager
