Integrity 2010, how can I tell who is signed on to the system right now?
mmcfadden
I believe I found it: Server Diagnostics and then License usage. Thanks.
Hi Michael,
License usage will provide the license usage statistics for the Integrity Lifecycle Manager server application. To identify who's currently logged/signed into the system, while in the Administration client, you can expand Server Diagnostics and then use Client Connections, then select the run button.
Dragan
2 REPLIES 2
Hi Michael,
Dragan
You can also use CLI command si diag --diag=licenses which will give you the license statistics.
