How to make the date picker widget responsive
AC_10460579
6-Contributor
if I fixed the container then it will remain same in all resolution.
and If I choose this, the entire screen get move when I click on the datepicker.
1 REPLY 1
jensc
(To:AC_10460579)
I am not entirely sure I am getting what your issue is, but it sounds like it is because you are using the "Stretch" option.
Try setting it to "None" and see if that helps.
Jens
