Xaxis labels are only showing for every other column - label chart
BP_10197309
6-Contributor
Hello Everyone,
I'm facing an issue with the label chart during runtime. Xaxis labels are showing alternatively when the mashup is viewed in chrome (100-67% Zoom), with zoom less or equal 50 all labels are showing.
Has anyone faced this issue before? How can I show all the labels even with 100% zoom on all screens?
Please share your valuable inputs.
Thanks in advance,
Bhavya P C
6 REPLIES 6
kparhad
6-Contributor
(To:BP_10197309)
Hi @BP_10197309,
Please advise the ThingWorx version you are running so we can try to recreate it here.
Will it be possible for you to provide the mashup and entities?
-kpankar
BP_10197309
6-Contributor
(To:kparhad)
Hi @kparhad ,
Thanks for your response. I'm using Thingworx 9.3.5-b1258 version.
As it is client project I'm not be able to share the same mashup but I can replicate mashup and share it with you
Bhavya P C
Hello @BP_10197309 ,
Could you pls try the following:
1. try diagnosing using Chrome developer tool and share the screenshot.
2. Use another browser like Firefox and check if the issue is still present.
Bhawna
M4RC
(To:BP_10197309)
you can set the "NumberOfXLabels" Widget-Property to the desired number.
Afterwards, regardless of the zoom, the same number of values should always be displayed.
Best regards
Marc
BP_10197309
6-Contributor
(To:M4RC)
Hi Marc,
Thanks for the response
I'm using label chart widget and we don't have "NumberOfXLabels" Widget-Property.
Bhavya P C
M4RC
(To:BP_10197309)
There seems to be no function for your case in the Label Chart.
So I recommend switching to the bar chart with the ChartType "Column Chart" (or "Pareto Chart Widget (Themable)") and possibly some configuration effort to keep the style.
Best regards
Marc
