Thingworx Flow on Linux Server
pshashipreetham
As per the prerequisites of Thingworx Navigate, Thingworx Flow need to be installed. So, Can Thingworx Flow be installed on a Linux Server? I went through the docs and found no installer for the Linux OS.
Shashi Preetham
1 ACCEPTED SOLUTION
Supported Operating System (64-bit only)
Windows Server 2016
Windows Server 2019
ThingWorx Flow 9.0.0 and 9.0.1 is supported on the following versions:
Red Hat Enterprise Linux (RHEL) 7.5
Red Hat Enterprise Linux (RHEL) 7.6
Red Hat Enterprise Linux (RHEL) 8.0
Red Hat Enterprise Linux (RHEL) 8.1
ThingWorx Flow 9.1 and ThingWorx Flow 9.0.2 and later is supported on the following version:
Red Hat Enterprise Linux (RHEL) 8.2
ThingWorx Flow 9.3 later is supported on the following version:
Red Hat Enterprise Linux (RHEL) 8.4
Article - "How to install or upgrade ThingWorx Flow offline(no Internet access environment) in Linux system": https://www.ptc.com/en/support/article/CS322896
1 REPLY 1
Windows Server 2016
Windows Server 2019
