if the step instruction said
“step 10: If any of the 3 sensors is dirty, go to step 15”
Step 11: Move to next check location
Step 14 : do A and B and C and hen skip to step 16
Step 15: follow these cleaning steps … first XXXXX, then YYYY etc .. finally ”
Step 16 : proceed normally
Hi @oparfon
You can navigate to any step needed in Vantage by going to the Step List. The Step list is available in the upper left corner:
Once in the step list - users can choose to view any step in the procedure:
This would require the user to manually navigate to that step.
Hi @oparfon
Olena,
We did this similar to the way tmccombie recommended.
We had a step that was solely for routing.
So it would the operator would following the step (say step 😎 to determine if any of the sensors were dirty.
Then the next step would say
"If any of the 3 sensors is dirty, continue to the next step.
If they are all clean, go to step 11"
If would be great if there could be some software/application routing, we would use that all the time.
