Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Ability to annotate an image from within a procedure step
All current and newly uploaded assets(images, videos and Captures) will be private by default and will only be available to the asset creator and org admins
NOTE: Editor users can share an asset with the entire organization or individual users for any asset they create.
