CSS styling for tab strip
IB_10645210
Hi, PTC community,
Please advise how to solve the CSS styling issue for the tab strip class.
So it looks right: like it should and written on CSS on the 2D canva, but it doesn't look right on a preview.
I also tried the text do not wrap, so I will appreciate if someone can share solution for this also.
1 ACCEPTED SOLUTION
couple of things
try using
.twx-tabs {
and also use !important on definitions if its not cascading
If you want you local  definitions to override use !important;
for example
border-color: #ddd !important;
Next try overriding the main class
.twx-tabs
hope this works for you
2 REPLIES 2
couple of things
try using
.twx-tabs {
for example
.twx-tabs
@sgreywilson Thank you!
