As per the original post.
@RolandRaytchev How to implement this Json file with annotation description text ? From sequence file?
Hi @IB_10645210 ,So far I understood your request : you want to have some kind of extraction from pvi , sequence /figure to json file so that we can use this information in any codes
So want to provide here an simple example for parser that will e.g. read the pvi file and then write it a json file. So follwong steps
figureName = "Assemble"
and call in windows shell where a node.js is installed the following script (let say the name is myStepTool.js) :
/********** myStepTool.js *************/
let figureName = "Assemble"
let xmlFileName ="l-Creo 3D - " +figureName+".pvi"
let jsonFileName = figureName+".json"
//name is "l-Creo 3D - Assemble.pvi"
var request = require('request');
var fs = require('fs');
let myXmlData=[]
let myArr = []
let myJsonArr = []
let TempjsonObj={stepNumber: 0 , step_name_locid: "" ,
step_name:"",step_acknowledge:false,
step_description_locid:"",step_description:""}
xml2js = require('xml2js');
var parser = new xml2js.Parser();
fs.readFile(__dirname + '/'+xmlFileName, function(err, data) {
parser.parseString(data, function (err, result) {
//console.dir(result);
let seq_s=result['galaxy_3di:figure']['galaxy_3di:sequence']
//console.log(JSON.stringify(seq_s))
//console.dir( seq_s[0]['galaxy_3di:sequence_step'] )
//console.log( seq_s )
console.log('Done');
let prop_animats=seq_s[0]['galaxy_3di:sequence_step']
prop_animats.forEach(el_function1)
console.info("jsonArray\n=================\n")
console.log(JSON.stringify(myJsonArr))
fs.writeFileSync(__dirname + '/'+jsonFileName, JSON.stringify(myJsonArr, null, 2) , 'utf-8');
function el_function1(item, index, arr) {
let jsonObj= JSON.parse(JSON.stringify(TempjsonObj))
jsonObj.stepNumber= index;
myArr[index] = item['galaxy_3di:property']
//console.log("myArr["+index+"] = "+myArr[index])
//console.dir(myArr[index])
//console.log("myArr["+index+"][1][\'$\'].value = "+myArr[index][1]['$'].value)
console.log("myArr["+index+"] ["+ myArr[index][0]['$'].name+ "] = "+myArr[index][0]['$'].value)
jsonObj.step_name_locid = myArr[index][0]['$'].value
console.log("myArr["+index+"] ["+ myArr[index][1]['$'].name+ "] = "+myArr[index][1]['$'].value)
jsonObj.step_name = myArr[index][1]['$'].value
console.log("myArr["+index+"] ["+ myArr[index][2]['$'].name+ "] = "+myArr[index][2]['_'])
jsonObj.step_acknowledge = myArr[index][2]['_']
console.log("myArr["+index+"] ["+ myArr[index][3]['$'].name+ "] = "+myArr[index][3]['$'].value)
jsonObj.step_description_locid = myArr[index][3]['$'].value
console.log("myArr["+index+"] ["+ myArr[index][4]['$'].name+ "] = "+myArr[index][4]['$'].value)
jsonObj.step_description = myArr[index][4]['$'].value
myJsonArr.push(jsonObj)
>> node myStepTool.js
"stepNumber": 0,
"step_name_locid": "stepName_2728332481823371952_2",
"step_name": "Assemble",
"step_acknowledge": "false",
"step_description_locid": "",
"step_description": ""
"stepNumber": 1,
"step_name_locid": "stepName_5894254086109201976_2",
"step_name": "Step 1",
"stepNumber": 2,
"step_name_locid": "stepName_15897802472779891525_2",
"step_name": "Step 2",
"stepNumber": 3,
"step_name_locid": "stepName_4089111003020719364_2",
"step_name": "Step 3",
"stepNumber": 4,
"step_name_locid": "stepName_1444424151131004256_2",
"step_name": "Step 4",
"stepNumber": 5,
"step_name_locid": "stepName_16935999301123799101_2",
"step_name": "Step 5",
"stepNumber": 6,
"step_name_locid": "stepName_4549226109679838932_2",
"step_name": "Step 6",
"stepNumber": 7,
"step_name_locid": "stepName_11110415484410389698_2",
"step_name": "Step 7",
"stepNumber": 8,
"step_name_locid": "stepName_11227030841165917496_2",
"step_name": "Step 8",
"stepNumber": 9,
"step_name_locid": "stepName_307606632875771006_2",
"step_name": "Step 9",
"stepNumber": 10,
"step_name_locid": "stepName_5267734679139784604_2",
"step_name": "Step 10",
"stepNumber": 11,
"step_name_locid": "stepName_18093258235493727066_2",
"step_name": "Step 11",
"stepNumber": 12,
"step_name_locid": "stepName_8642537011799624768_2",
"step_name": "Step 12",
"stepNumber": 13,
"step_name_locid": "stepName_9423943722212754853_2",
"step_name": "Step 13",
"stepNumber": 14,
"step_name_locid": "stepName_6512444656035031150_2",
"step_name": "Step 14",
"stepNumber": 15,
"step_name_locid": "stepName_14841759718657189243_2",
"step_name": "Step 15",
"stepNumber": 16,
"step_name_locid": "stepName_7345189520540227377_2",
"step_name": "Step 16",
seems to be related to the post: and the sample project ?
Or is this new quesiton? could you ,please, check and provide details if required. Thanks
@RolandRaytchev Thank you for suggested solution.
I have sent details through message. Please check. I would appreciate any suggestions.
let myXmlData=[]
let myArr = []
let myJsonArr = []
>> node myStepTool.js
"stepNumber": 0,
"stepNumber": 1,
"stepNumber": 2,
"stepNumber": 3,
"stepNumber": 4,
"stepNumber": 5,
"stepNumber": 6,
"stepNumber": 7,
"stepNumber": 8,
"stepNumber": 9,
"stepNumber": 10,
"stepNumber": 11,
"stepNumber": 12,
"stepNumber": 13,
"stepNumber": 14,
"stepNumber": 15,
"stepNumber": 16,
Thank you so much!!!!!! Instructions help a lot.
Hello @IB_10645210
Thanks for the feedback! Here is another verison which will read all pvi files in the current directory and will save them there as< FirgureName>.json. You do not need to set arguments it will extract this form the file:
/*** ++++ myStepTool.js ++++ ***/
const request = require('request');
const fs = require('fs');
const path = require('path');
let myArr = []
function readFiles(dir,processFile) {
// read directory
fs.readdir(dir, (error, fileNames) => {
if (error) throw error;
fileNames.forEach(filename => {
// get current file name
const name = path.parse(filename).name;
// get current file extension
const ext = path.parse(filename).ext;
// get current file path
const filepath = path.resolve(dir, filename);
// get information about the file
fs.stat(filepath, function(error, stat) {
// check if the current path is a file or a folder
const isFile = stat.isFile();
// exclude folders
if (isFile) {
// callback, do something with the file
processFile(filepath, name, ext, stat);
let processFile =(filepath, name, ext, stat)=>{
console.info("filepath >>:",filepath)
console.info("name >>:",name)
console.info("ext >>:",ext)
//console.info("stat >>:",stat)
console.info("size >>:",stat.size)
console.info("creationTime >>:",stat.birthtime)
let ret=0;checkStr="l-Creo 3D - ";
if(ext.indexOf('pvi') != -1)
{console.warn("ext is PVI")
if((ret=filepath.indexOf(checkStr))!=-1){
//console.log(" ret ="+ret+" >>"+name.substring(checkStr.length));
let nameFigure=name.substring(checkStr.length)
processData(filepath,nameFigure)
else console.warn("extension is not PVI")
function processData(fpath,nameFigure){
var dataset = {data: [],myJsonArr:[]};
let myArr = []
let myJsonArr = []
fs.readFile(fpath, function(err, data) {
function(item, index, arr) {
myArr = item['galaxy_3di:property']
jsonObj.step_name_locid = myArr[0]['$'].value
jsonObj.step_name = myArr[1]['$'].value
jsonObj.step_acknowledge = myArr[2]['_']
jsonObj.step_description_locid = myArr[3]['$'].value
jsonObj.step_description = myArr[4]['$'].value
dataset.myJsonArr.push(jsonObj)
},{_self:this,dataset:dataset}) });
console.info("jsonArray was done!\n=================\n")
//console.log(JSON.stringify(dataset.myJsonArr))
fs.writeFileSync(__dirname + '/'+nameFigure+'.json', JSON.stringify(dataset.myJsonArr, null, 2) , 'utf-8');
// below program execution in current directory
readFiles(__dirname,processFile)
console.warn("Done!")
@RolandRaytchev Hello Roland,
Could you show an example how this was applied within the project.
I am little stuck... research didn't help
