I have been doing some extension development, and have had pretty good success with it. But I'm struggling with one thing: I am trying to develop a 3D widget, with the usual x, y, z, rx, ry, rz properties to position it. The runtime preview respects these attributes as expected, but the design time view has a few issues:
I suspect items 2 & 3 are related.
So I guess I've left something out of my design JS file, but I'm not sure what I need to make the design canvas work the way it's supposed to. I've been using some of the OCTO extensions as a guide, particularly the Progress-3D widget.
Can anyone give me some tips on how to make sure the positioning functions in the design canvas work with my extension? @SteveGhee or @RolandRaytchev or @sgreywilson maybe?
Hi @ClayHelberg ,
I had in the past some attempts to use widget extensions where I noticed that some coordinates in 3d space are not corrected interpreted -but there I adapted the value so that it was working without further check what is the reason for such behavior. The specific behavior was different depending on the particular implementation, I believe. To understand the problem , possibly it will be helpful if there is an example which demonstrate the issue. You mentioned that it is based on specific extension progress-3d of the OCTO Extensions, but to be sure that we speak about the same thing , it will be better to have an example (simplified only to the relevant problem). Because I my self did not have so much experience with developments of extension - 3D so need to check more detailed and if required to ask the R&D team for further assistance. Thanks BR.
Hi @RolandRaytchev , thanks for the reply. I will attach a copy of my extension for troubleshooting.
Another update: I figured out the double-parameters issue in the design view: my design template has a <twx-dt-image> element, and I was passing the widget parameter values into that, but that meant that the parameters were applied on both the widget wrapper and the rendered image. I modified it to set the <twx-dt-image> parameters to 0, and now the positioning based on parameter values works as expected.
Still haven't cracked the other two issues though. In the design view, when I click on the extension widget instance on the design canvas, I see this error:
TypeError: ctrlWidget.select is not a function
The rendered widget seems to be some kind of derived object that's not a "real" widget--if I use the debugger tools to examine ctrlWidget, I see this:
So maybe there's something I need to be doing in the design JS to make sure the <twx-dt-image> has a proper controller?
Hi @ClayHelberg
I tested it and I have the same problems reproduced, so it seems that there are many issues. So I tried to check the extension from OCTO GitHub Progress-3D widget , what you mentioned that was taken as start template for your widget and it was not working in eyewear project. when I tested - possibly the version or some specific setting is required .. no idea
I checked if there is other source with simple 3D extension and think this one is simple and work fine ->open source Extensions for Vuforia Studio at GitHub repository
In this github repository there are several 3D extensions defined which does not use to much code but are relative simple. - e.g. tmlSVG see also
I think this extension uses some 3Dproperty as template and how it is designed make e.g. for me more easy to understand and customize it later - TMLSVG.design.js and 3dsvg.js
attached here the project where I tested this extension.
Hi Roland--
Do those SVG extensions work for you, especially using the dragger to move them and see the location parameters update? They don't work for me--I get the same errors with these that I am getting with my own extension. The dragger controls *seem* to work, but they don't actually update the location parameters. I tested with my own (new) experience and also the one you posted above.
Hi Clay--,
thanks for the clarification! OK , i think now understood the issue your reported ... but still have no idea about a possible solution. Therefore reported the problem to PTC R&D team as Ticket VTS-1783 and when there is a feedback I will share it there. I also mentioned in the ticket report the community topic so that possibly someone from the R&D team will directly joint to this post . Thank you!
Hi @ClayHelberg the issue in ticket Ticket VTS-1783 was idetified as bug and R&D will fix it. This functionality is not working generally for extensions. So accroding to the code of the extension it should be correct and should work when a fix is availible. currnetly is no info when the fix is planed (datecode) - there is only an info that R&D is working on the problem.
Thanks for the update @RolandRaytchev ! I'll watch for it in upcoming releases.
