Use External camera for Vuforia View
anupds
Hi Everyone ,
Can we use external camera that is connected in network to view Studio Experience using Vuforia View app installed on by Mobile / iPad connected on same network ?
4 REPLIES 4
Suraj_Patil
(To:anupds)
can you elaborate the situation more so that we can get clear idea ..
anupds
(To:Suraj_Patil)
Hi Suraj ,
Thank You for your reply.
Wanted to view AR Experience Created in Vuforia Studio at a factory shopfloor on my iPad but the camera I wanted to used to view this Experience should be External camera installed on Shopfloor. So that the complete equipment can be viewed from top view. Using iPad camera it is not possible to view from top side.
Suraj_Patil
(To:anupds)
i don't think so its possible here. above mentioned scenario is not the purpose of AR. instead what you can do is you can capture entire shopfloor with LIDAR sensor camera as model and bring it in vuforia studio or unity and that will suffice your requirement i guess.
anupds
(To:Suraj_Patil)
Okay Understood , Thank You for your reply
