Add a notification pane after an action
Sha11
Hello Peers,
I have the below requirements for which I am looking for some information, requesting you to provide the same if you have something from your end.
i) I have a custom action in WTPart action that updates an IBA value, I need to reload the window after the click of that action so that the value update will be reflected in the UI.
ii) After a click of an action, I want to display a notification pane with some information similar to what we see when we create a new object in Windchill.
Sha
1 ACCEPTED SOLUTION
HelesicPetr
(To:Sha11)
Hello @Sha11
What you are looking for is a Inline Message.
An example is shown in a Windchill catalog.
 <serverAddress>/Windchill/app/#netmarkets/jsp/componentCatalog/inlineMessageComponent.jsp
Additional information is in a help center Inline Messaging
here is example how to create some feedbackmessage in the Processor class.
@Override
public FeedbackMessage getSuccessFeedbackMessage(List< ObjectBean > list) throws WTException
	WTMessage title = new WTMessage("com.ptc.core.ui.successMessagesRB", "OBJECT_CREATE_SUCCESSFUL_TITLE", (Object[]) null);
	WTMessage message = new WTMessage("com.ptc.core.ui.successMessagesRB", "OBJECT_CREATE_SUCCESSFUL_MSG", (Object[])null);
	if (list != null)
		ArrayList<Object> createdObjects = new ArrayList<>();
		try
			Locale sessionLocale = SessionHelper.getLocale();
			FeedbackMessage feedbackMessage = new FeedbackMessage(FeedbackType.SUCCESS, sessionLocale, title,null, createdObjects, message);
			String[] incorrectTextArray = {"MY TEXT", "ALL IS OK"}; // next example of text added to the feedback message
			if (incorrectTextArray != null)
				for (String incorectMessage : incorrectTextArray)
					feedbackMessage.addMessage(String.format("<span style=\"color: red;font-weight: bold;\">%s</span>", incorectMessage));
		} catch (WTException e)
			//e.printStackTrace();
	return null;
Hope this can help.
PetrH
1 REPLY 1
HelesicPetr
(To:Sha11)
Hello @Sha11
@Override
	if (list != null)
		try
	return null;
Hope this can help.
PetrH
